Posted by Owen Aaland on September 30, 2011 at 19:36:49 from (216.47.32.147):
In Reply to: 1256 injection pump posted by DeltaRed on September 30, 2011 at 19:21:20:
You have the typical symptoms of a pump getting air in it. It doesn't happen often but you may have an air leak in the system but yet not leak fuel out. Most often it is a hose. It gets pulled in a little from the vacuum of the charge pump and then expands back again when not running so you have no fuel leaking. Any leak above the level of the fuel in the tank can also let in air but not leak fuel.
Be sure to check at the timing window to see if there are any "coffee grounds". That would indicate the weight retainer ring is breaking up and restricting the return.
This post was edited by Owen Aaland at 19:38:42 09/30/11.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
