Posted by 36F30 on October 01, 2011 at 15:28:30 from (71.38.169.170):
In Reply to: F 12 valve timing posted by Craig45 on October 01, 2011 at 14:22:49:
Page 33 of my 1935 F12 instruction book says to set valve clearance at .016. It says nothing about them being set hot.
To check the valve timing first set the valve clearance as above and then with number one piston at TDC rotate the engine just to the point all play is taken up in the intake valve lever. Then look on the flywheel there is an I/O mark on it and it should be within 3/8" either way of the timing mark on the bellhousing. If its not, your out of time and I would look at the front crank gear, I have found a couple that ate up the keyway and were loose enough to affect the valve timing.
This post was edited by 36F30 at 15:30:11 10/01/11.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
