Use a test light. they are ~2.50$ They look like a small screw driver and have a wire attached. The power should be found at the wire supplying the fuse, both ends of the fuse, the bracket of the fuse holder to the switch, the wire connecting to the lights, and at each light. Poor connections at any point will thus be evident. The dimming resistor on the IH light switch must be good to have Dim lights. If it is not good, there will be no voltage for the test light on D position. If the tractor is equipped with light bulbs or sealed beams from other applications that draw more watts than the original, the D position will burn out the wire resistor in a flash. the switch is not good for much more than the original lights, unless run through a power relay to avoid over loading the switch contacts. Keep us in the loop. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
