Re: Belt pulleys
Posted by Farmer Bob on August 22, 2000 at 21:58:23 from (208.49.9.81):
In Reply to: Belt pulleys posted by Rob Johnson on August 22, 2000 at 21:26:12:
Rob, Years ago we used the belt pulley to run a Papec insulage chopper/blower for filing silos. The belt is either run straight or with a twist in it depending upon which way you want your saw blade to turn. As far as tensioning goes, as long as the belt doesn't slip you should be okay. Alignment is fairly simple if your running a saw that's mounted on the tractor. If it's a separate unit you'll have to adjust the position of the tractor to ensure the belt runs true to both pulleys. Please remember that a saw is an extremely dangerous implement. Use extreme caution while doing anything around it! We want you back on here talking about your experience(s)//FB
Post A Followup
: Re: Re: Belt pulleys
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
