Re: super c with hicups
Posted by pete 23 on October 04, 2011 at 11:11:11 from (74.32.234.149):
In Reply to: super c with hicups posted by nc super c 1 on October 03, 2011 at 20:35:57:
You need to determine if leak is in cyl or check valve. With hitch raised, load on it, engine shut off, see if the hose on rod end of cyl(which is not supporting the load) has pressure in it, if it does your cyl is leaking. May require unhooking hoses to determine. If oil comes out of that hose, cyl leak. If oil actually lowers in hose, check valve is leaking. Just be sure you check correct hose as of course the one to lower end of cyl will have pressure.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
