Posted by Larry B 1486 on October 05, 2011 at 12:50:47 from (98.19.164.141):
Two years ago I replaced the motor in my 856 with a DT 361 1206 motor. The D407 motor in my 856 diesel was past wore out and I found a 1206 that was wrecked, parking brake did not hold rolling down a hill and a oak tree removed the right rear axle and busted the clutch housing. The motor had less than 1600 hrs on a rebuild. I know the injectors need to go to the shop and the solar turbo has been replaced with on off a 1066 with a adaptor plate between it and the manifold. The motor don't have the power it should so i checked the intake pressure and under load, motor hot 2100 rpm's pulling it hard it only comes up with 2 to 2 1/2 lb pressure. Don't it need around 8 to 10 lb's psi? This the wrong size turbo? It was on the motor when I bought it. I took The air cleaner off the 1206 also so it has the big air cleaner with new filter. My 1466 runs around 8 to 10 psi under load. Do I need to change turbo and if so what will work on this motor?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
