Posted by rustyfarmall on October 06, 2011 at 14:27:46 from (216.248.71.224):
In Reply to: W4 Fuel Problem posted by BLACK on October 06, 2011 at 14:04:34:
My guess is that you didn't go far enough when you took the carb apart the second time. The float might be sticking on the hinge pin, or the needle valve might be stuck in the seat. Unless you thoroughly cleaned out the gas tank when you first got it running, there is still some old, varnished gasoline in there, and that is what is causing your fuel problems. Eventually, that old gas will get diluted enough that it will no longer cause problems, or you can have the tank cleaned out and eliminate the problem right away.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
