There should be a pointer on the engine front cover pointing at the rear flange of the crank pulley. TDC is when the LAST notch in the pulley flange aligns with the pointer (crankshaft being turned in the normal direction of rotation).
However if the pointer is missing all is not lost! Do this:
Remove the #1 (front) spark plug. Stick your thumb over the opening then rotate the crank until you feel pressure building - ie. #1 piston coming up on compression. Now poke a pencil or stiff copper wire into the combustion chamber. Continue turning crank slowly and "feel" for the top of the piston coming up. When your feeler stops moving you will be at TDC. (You should also now see the top of the piston thru the plug opening).
Now turn the distributor drive until the rotor is under the #1 plug tower, then mount it to the engine. Your engine should be timed close enough to start and run. It however will probably need a minor timing adjustment to achieve smoothest running.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
