Posted by smallercrawler on October 07, 2011 at 07:24:24 from (166.82.254.181):
Hi all, I ran into a problem with an Continental F124 gas engine in a 1950 U.S. Trac dozer. As these engines were used in some IH/Farmall, thought someone might help. Engine has been running fine for last several years, started and worked for a couple hours each month. Started up good yesterday and ran ok for an hour or so. Began stalling/missing, thought it was what is called gasoline these days so checked fuel system-nothing apparent. Was running at 1500 RPM when it backfired 3 or 4 times, coughed, and stopped. Would crank, but not start with frequent "chuffing"/backfire. Found distributor rotor had broken on shaft. Cleaned plastic from distributor, installed new one and same thing. Changed to new plugs (gapped ok), 2 known good coils, and checked point gap, compression good, still same problem. It now looks like rotor is between 2 plugs and trying to fire both, rotor moves smoothly-doesn't appear cam gear damaged. Distributor body hasn't moved. What has apparently changed timing by about 45 degrees?? Sorry for long post, trying to anticipate questions. Thanks for any help offered.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
