Posted by Janicholson on October 07, 2011 at 22:31:30 from (67.72.98.45):
In Reply to: Smokin' Super A posted by Chuck Puett on October 07, 2011 at 22:09:36:
Old sure makes things work!! Listen to him. I think that if there is a ridge in the engine .05 or more deep at the top of the ring groove, you will use oil. If it is less than that (and mine because I am a mechanic) I would just ridge ream, hone and replace the piston rings. If the oil use is continuous when running under load, and it has many hours, It is probably in need of a Kit with sleeves and pistons. A set of stuck rings will also produce oil consumption. Putting 1/8 cup of ATF in each cylinder and letting it sit for 2 weeks with the plugs back in, then removing them and cranking it over to blow out any excess oil, then starting and running it for several hours under a load might free them if they are going to free up. If they don't do the ring job. Committing to a ring only repair with no more information than we have can be unsuccessful. If the smoke is prominent when idling around, or going down hill when coasting, or only on start up, I would put valve seals in it without removing the head and see what happens (cheap and easy). Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
