M Farmall brake pedal shaft
Posted by Haas on August 23, 2000 at 13:32:58 from (129.37.117.187):
It looks like transmission fluid is coming out around the shaft on my MD to which the brake and clutch petals are attached. I assume this shaft must go through the transmission and that there is a seal where it goes through the housing. How to change the seals??? I assume remove the pedals and slide the shaft out. Then pry out the old seals and press in new ones. Then reassemble. Is all this correct?? Or...is there something more complicated here??
Post A Followup
: Re: M Farmall brake pedal shaft
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
