Okay, heres the deal, on a 12 volt tractor you can do EITHER:
(Short answer to your immediate question: YES, if you use a 12 volt coil, remove the ballast)
a) Use a 12 volt coil (some call internally ballasted) with NO EXTERNAL BALLAST RESISTOR between the ignition switch and the coil
b) Use a 6 volt coil WITH AN EXTERNAL SERIES VOLTAGE DROPPING (12 to 6) BALLAST RESISTOR BETWEEN THE IGNITION SWITCH AND COIL.
NOTE an Ignition Switch must obviously supply 12 volts to a 12 volt coil ONLY when switched ON but not when OFF DUHHHHHH Some mag kill switches supplied a ground to the mag when OFF but no connection to the mag when ON. YOU NEED AN IGNITION SWITCH with a hot BAT voltage input connection and then the IGN out terminal goes hot when its switched to ON
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
