As was said, the hay nwas fed in the bailer in the hole above the plunger setting atop the bailer. Usually by 2 or 3 people. If all the hay forks that the plunger had got hold of and broke could be counted and rebought, The price of their worth likely would buy you a new bailer of any make. Youll need you 2 for sure, maybe 3 wood blocks. These are made out of GOOD heavy boards of true 1 by. These blocks will fit on end smoothly in the rear where the bales come out. There will need to be 2 although one GOOD man could do it, and that is to tie the wire around the bales. Youll need to find a source for stationary bailing wire. I think its still available. It is straight, maybe 10ft long with a loop on one end. There should be a carrier device on the opposite side of the hole from the plunger that comes back out, and in over the hole. When ready to start a new bale, you insert a block into this device, and when the packer is raised, you rock it forward. The packer will take it on down into the plunger area, and the plunger will begin to move it out the end with the addition of more hay. You have a tyer on both sides. The blocks are made like a H. The middle comes up to within around 2in from the top and bottom. You put in a block when the bale has come to a predetermined place so that the bales remain consistant in size. Ive pitched to a JD bailer of of a straw sstack of threshed straw. The stack got further and further away from the bailer as we were pitching it in, and I suggested to the operator that we might relocate the bailer closer to the stack when the biggest bolt of lightening came straight down. He said, (Mebbie we wont have to).
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
