Posted by Owen Aaland on October 10, 2011 at 21:00:31 from (216.47.32.147):
In Reply to: Super M Tranny Oil posted by Mark in Upstate on October 09, 2011 at 18:33:29:
You've got to get to a 706 or larger tractor to have a transmission brake.
With the release of HY-Tran it also became the recommended lube for the older tractors replacing the 90 weight lube oil. There is no harm in using it, it just has some disadvantages compared to the heavier oil.
Something else you may run into with Hy-Tran is gear rattle at low idle when the transmission is in neutral. The crankshaft speeds up each time a cylinder fires and then slows down again until the next cylinder fires. This uneven speed can cause noise with the thinner oil because of the back lash in the transmission gears. A thicker coating of because of higher viscosity will cushion the gears a little better.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
