Posted by ADLM on October 11, 2011 at 13:59:58 from (72.156.145.199):
I am finding that my Farmall A does not like to go into gear after I first hit the clutch when the transmission is in neutral. It will not go into any gear unless I force it in, making the gears grind a lot in the process. Then, I can drive it, use the pto, and change gears just fine without any grinding at all. But if I ever let out the clutch with the tractor in neutral, when I try to go back into any gear the same grinding process as before is repeated. It does not matter how long I wait after pressing the clutch, if I'm in neutral the gears will grind. Does this mean time to replace a clutch, or is something else causing this problem?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
