I put the shaft in without all the other stuff on it like hydrostatic pump and swash plate. Get the shimming for correct amount of end play. It requires pulling that front bearing cup to add or subtract shims. Been many years since I did it though so may be forgetting a few things. I just never liked to do it the way the book shows. End result is the same only this way you can actually measure end play. One thing you have to remember about measuring end play on any tapered roller bearing shaft is you turn shaft several times and then you measure by prying shaft or pulling shaft. After you pry or pull it one time you have to rotate it again to get an accurate measurement. I never actually realized that myself until they showed us this procedure when at service training on the CaseIH magnum tractor transmissions. And yes, those charge pumps do tear up.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
