The installed valve stem height is the same no matter which head is used on the M. If the valves are too long your replacement head is either for distillate or kerosene. Gasoline head valves are the longest.
The machine shop should have know the installed valve spring height was wrong. They would have needed a lot of spring shims to get the height correct, enough to know that there was a problem with the valve length. even if they were such a thing as longer push rods you would need to raise the rocker shaft enough to compensate for the increase valve height and without a lot of spring shims the spring pressure will be way too weak. Then you would need to lengthen the oil supply tube to feed the rocker shaft. When you got that done the rockers would most likely hit the vapor vent tube and may even make contact with the valve cover.
The only real solution is to redo the job and make sure the valves are correct for the head being used.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
