Posted by CNKS on October 16, 2011 at 08:03:50 from (216.144.104.128):
In Reply to: H Carb Setting posted by George rausch on October 16, 2011 at 05:58:06:
Read further. The manual gives a starting point so that it will run. When the engine is warm and at wide open throttle turn the main jet screw in until it starts running rough, then out until smooth, maybe 1/4-1/2 more turn out (better slightly lean than rather than rich), then move the idle jet out and in at low idle until smooth. Rapidly move the throttle to WOT, it should accelerate smoothly with no roughness. If it doesn't repeat the process until it does. If it does not behave you need to overhaul the carb. Makes no difference where others are set. Just follow the procedure--this procedure is better worded in the Operators manual.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
