Posted by IH fan on October 16, 2011 at 20:50:52 from (99.103.254.74):
In Reply to: water in hydralics posted by Smd1925 on October 16, 2011 at 17:56:49:
Darn near impossible to get all the water out of a system with one change, unless you disconnect every hose, valve, pump and cylinders and completely drain them. Used to get leaks in heat exchangers in our test stands and even with draining everything we could get loose or open, there would still be water hiding in there somewhere. When we got as much out as possible, we left the reservoir open and heated the oil above boiling while circulating it. sometimes took a day or two to boil out that last water. One point here.... it takes surprisingly little water to make oil "milky" below the boiling point of the water in it and above the boiling point, it can appear to be clear. If you have changed it 3 times, there is probably not much water left. Water is highly errosive in high pressure systems, but if your system is 1500psi or lower, it can probably tolorate a little water.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
