What makes you think you flooded it? Was it dripping gas?
Try turning the gas off completely, and starting while the gas is off. If the carb is dripping while you're doing this, wait a while, and re-try. At some point the carb will drain enough to be at the right level to run properly.
If it catches, quickly turn the gas back on.
That should at least get you running again, but it of course doesn't solve the underlying problem.
Although, sometimes you just need to get things flowing and they magically fix themselves.
Hard to say just what the problem is since this is your first run. But if you do get it running again, that should at least give you more information to go on.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
