Re: M with Heisler od pops out of low side
Posted by Janicholson on October 18, 2011 at 17:13:27 from (67.72.98.45):
In Reply to: Re: M with Heisler od pops out of low side posted by IAJosh84 on October 18, 2011 at 15:23:38:
The heisler is going to be the cause. THe heisler runs the countershaft at a speed that provides the new ratios. In the lower gears, it also drives the countershaft (at the original speed) thus in either "gear" it uses the heisler. Parts may be hard to find, but if searched for can be had. If anything, it can be taken back to stock 5 speed with the removal of the heisler components and the replacement of those with the constant mesh input and countershaft gears from a donor tractor trans. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
