What Allan was talking about is the snap ring on the end of the shuttle valve. The shuttle valve is accessed by removing the recessed square plug the arrow is pointing to in Allan's photo. Once the plug is out there is a cap with a slot in it that you unscrew to get to the shuttle valve. The snap ring is on the end of the valve under the cap. In the parts diagram (Power Train > B-10 Power Train, Center Section Body And Related Parts, Tractors With Hydrostatic Drive) the shuttle valve is # 9 and the snap ring # 13.
As far as what I was talking about, I understood that the problem only occurred once when you were operating the tractor. Then after you shut it off the problem again would only occur once the next time the engine was run. As long the tractor was not shut off the problem only occurred one time.
Hopefully you are checking the trans/hydraulic oil level only after the tractor has been run for at least two minutes at 1200 RPM or above. There are no oil seals as such that seal between the hydro section and the rear frame, only shields that restrict the oil flow. With the engine off the oil will quickly drain out of the hydro section until the level equals that of the rear frame. At low idle there may not be enough flow to fill the hydro section so the engine need to run at a faster idle to be sure it fills with oil before checking.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
