Hold your hand over the throat of the carburetor while a helper try's to make an engine start. If there's not much suction on your hand is an indication of low manifold vacuum. Make sure your intake manifold is tight. Open your main jet adjusting screw near the bottom of the carb. I would check the flow of gas from your tank to the carb. If there's good flow from the tank remove the tube fitting where your gas line connects and check for a plugged screen behind that fitting. If none of this helps remove that main jet adjusting screw and blow out the jet with air pressure. Hal
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
