M clutch stuck update
Posted by Dale_MN on October 20, 2011 at 05:17:23 from (208.38.113.117):
third party image
third party image
I pulled the belly pump and had a chance to visually inspect the clutch. I'm not familiar enough to know how things should look but the release bearing assy moves easily and engages the 3 levers when the clutch is depressed (pics show clutch pedal released and depressed). I assume that means the friction disc is stuck to the drive plate. Is this a symptom of a clutch that in the near future will need to be rebuilt? Also, the seal on the input shaft for the belly pump has been leaking. It looks like a the seal and bearing are held in place by a casting. Removing the cap bolts and casting would give access to that seal, or is it more complex than it looks?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
