Re: 806 engine noise
Posted by The tractor vet on October 20, 2011 at 21:11:43 from (75.19.123.11):
In Reply to: 806 engine noise posted by 450dieselfan on October 20, 2011 at 21:00:43:
when adjusting the valves you need to pay attention to the ware on the rocker arm as they do not ware even and there is always a little rocker arm hanging over the valve stem and when you stick the feeler gauge between the rocker arm and the valve stem you get a bridging and this will throw your set off and you will have a few loose ones . So go back over them again and look real close and you will see what is going on . Now IF you get it down and ya still have noise then you may have a guide issue . Also take a long handle screw driver and place the end against the block by each piston and put your ear to the handle and listen you may also be hearing piston slap .
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
