Re: two gas tanks?
Posted by john d on August 25, 2000 at 14:13:04 from (206.141.74.34):
In Reply to: two gas tanks? posted by Pete in PA on August 25, 2000 at 13:57:50:
The tractor was a "distillate" tractor, designed to start on gasoline (small tank) and run on distillate (large tank) when warmed up. under the tanks you will find the necessary valves for switching one to the other, unless that stuff has been removed.
The tractor has been around long enough that it's likely been considerably modified from the original setup. It originally had the distillate, or "hot" manifold, which has almost certainly been replaced by now if the tractor has been working on gasoline. It also came with a distillate head, which was low-compression, and that means a small horsepower sacrifice unless it's been replaced, or the engine equipped with high-compression (high altitude) pistons. Most of these old tractors have either had the small tank removed, or used as a reserve gasoline tank.
Unless there is proof to the contrary, assume this thing is used to running on gasoline.
Post A Followup
: Re: Re: two gas tanks?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
