The I&T manual has the instructions for assembly of the valve. The gears and the yoke are set in a neutral position and the input and follow-up levers are set to specific angles from vertical. I've done this on a 340 but don't know if the angles are the same for a 460. On the 340 it also depends on whether the cable or rod system is used for the teledepth valve. On the 340, the axis of the yoke and gears is parallel to the cover surface; the input lever is set to 7 1/2 deg. to the rear from vertical; the follow-up lever is set to 6 deg. to the front, from vertical. Hope this helps.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
