Re: Farmall H Carb
Posted by wayne in mn on October 25, 2011 at 19:18:26 from (24.179.162.165):
In Reply to: Farmall H Carb posted by Pat Connors on October 25, 2011 at 08:20:29:
As a starting point: high-speed mixture screw set at 3 turns out, idle air screw set at 1 1/2 turns out.
Start the engine & warm it up in NEUTRAL and BRAKES LOCKED. Run at WOT (wide open throttle) and turn the high-speed adjusting screw in & out to find the "sweet spot" where the engine runs its fastest & smoothest. Turn this high-speed screw out an extra 1/2--3/4 turn for power. Idle the engine down & set the idle rpm's. Now turn the idle air screw in to richen, out to lean so the idle is smoothest (this is an AIR adjusting screw so works opposite of the main fuel screw on the bottom of the carb). Re-adjust the idle rpm's. Repeat the carb adjusting procedure another time to be sure all mixtures are correct.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
