Re: 300 Utility hydraulics baffling me
Posted by pete 23 on October 26, 2011 at 10:46:55 from (74.32.238.142):
In Reply to: 300 Utility hydraulics baffling me posted by Aaron B on October 25, 2011 at 09:56:24:
The pilot valve Jim referred to is the regulator valve in the block with the four bolt cover and heavy spring under it. It contains the regulator valve, relief valve and orfice screen which feeds the regulator valve. I have seen those orfices drilled out too large and cause your problem. Original was .024 and replacements are .031 so it is a very small hole indeed. Also, if the orfice is loose in the block it can cause your problem. It is a screwdriver slotted orfice with screen on it. The regulator piston has an o-ring on it that can leak and the piston is also spring loaded and that can break internally. It should have considerable resistance to make the button on bottom of piston move against the spring. Then , you might have a loose ball and seat under regulator piston. No one size fits all repair as there are many things that can cause your problem. Leaking o-ring on suction tube to pump also.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
