Posted by SouthernFarmall on October 26, 2011 at 16:01:59 from (71.48.204.136):
I have had this Cub just sitting around the farm for a couple years. I knew it had some issues, but I didn't worry about them because the tractor was never needed. I have now decided I'm going to fix it up a little bit. I will appreciate any and all advice! Here are the issues I know of right now:
1. Overheating. It will start spitting water/antifreeze out of the the overflow hole within 10 minutes of running. I wouldn't think that would be enough time to even get it up to operating temperature!
2. Throttle control. The Cub will usually run okay, but I really only have two throttle positions - full throttle and low idle. It's usable the way it is, but it certainly gets annoying. I have no idea what could be causing this, but I have to assume it is the governor. I can move the lever through the full range of motion, but the governor doesn't respond until I have moved the lever all the way forward or back.
If I have any other problems surface, I will let you all know. Thanks!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
