Posted by John T on October 27, 2011 at 11:13:44 from (173.243.181.15):
In Reply to: Cub ignition posted by RGMartin on October 27, 2011 at 08:01:19:
Sure you can, the other fine gents have shown how to wire it, youre just using the points in the mag to cause the external coil to conduct then interrupt its current flow. HOWEVER remember that mag only has two timings, static start timing and advance run timing, NOT an RPM based variable advance like a real distributor coil ignition, and as such wont perform quite as well. One problem can be if a dude takes a small Cub and converts it to 12 volt the starter may spin her over so fast its trying to start at the non retarded (run time advance) timing cauasng kick back and starter problems.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
