Posted by El Toro on October 28, 2011 at 14:43:58 from (108.40.22.75):
In Reply to: 40 B runs then dies posted by scott strother on October 28, 2011 at 14:35:14:
Make sure you're getting gas to the carburetor. Check the flow from the tank by disconnecting the gas line at the carb. Hold a clean container to catch the gas. If there's a full stream of gas from the tank remove the tube fitting where your gas line connects. Look for a screen behind that fitting that be plugged with dirt or rust. If it's looks clean you probably need to remove the carburetor and soak it in carb cleaner and blow out the jets. Check your float level. Hal
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
