[What would happen if I changed it to a positive ground?]-You would straight away blow the diodes in the alternator and let all the smoke out-LEAVE IT AT NEGATIVE ground
[I did not change the fields in the starter]-Not required-starter is a series wound motor and will rotate in the same direction whether + or -ve ground
I have it neg. ground but I went to IH and they say positive ground on the 12 volt gas. Is that my problem?-NO YOU-PRESUMABLY-correctly changed it to Negative ground to fit the Alternator
I would guess your problem is a bad connection, somewhere in the wiring from the +ve battery terminal to the starter solenoid operating coil connection [Sometimes marked S]-you say there is no solenoid "click" when it fails. So, whatever you do, don't change the Polarity and post back with the results of the checking for +12 volts at the solenoid S terminal on an attempted start. Make sure you are not going to be run over etc if it does start
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
