Some things to try when it doesn't start. If sure the battery cables and connections are okay and you have the original type starter switch on top of the starter. Test to see if power is on the small terminal when switch is turned to start. Or making sure the tractor is out of gear, jump power from the battery cable terminal to the small one. If that doesnt crank it run a jumper cable from positive or starter battery cable to starter post or strap going to the post, this would bypass the starter switch. Small terminal no power = bad ignition switch or a bad connection from or to the switches. Bypass starter switch and starter works = bad starter switch. Jumper cables from positive battery terminal to starter post and the negative to good ground = bad starter or bad battery. If tractor has a later type starter switch with 2 small terminals the small terminal with a S will energize the switch.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
