Posted by pete 23 on November 02, 2011 at 17:54:26 from (74.32.238.142):
In Reply to: Re: shutting of an A posted by Charlie M on November 02, 2011 at 12:53:15:
You are correct, you should be able to kill engine by grounding the terminal at magneto. The thing that puzzles me is that the wire from the points runs to the condensor and that is where the shorting wire is hooked to, so how it can run well if that wire is not good or not hooked up is a good question. At any rate, your kill wire to switch has to be making contact with the threads on end of condensor.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
