Re: Cub governor adjustment.
Posted by screwstick on November 03, 2011 at 13:36:21 from (174.24.0.234):
In Reply to: Cub governor adjustment. posted by ccaissie on November 03, 2011 at 11:31:38:
Check the governor spring to make sure it's not worn out or the holes are not wallered out causing the hesitation. There is no adjustment to the governor itself besides setting max RPMs. If it is sticky, then removal and a good cleaning might be in order. There is a small needle bearing on the output shaft, and it has a woodruff key that often develops play in groove. The support arm that comes off the front of the block is another place to look that causes resistance.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
