I left alot of detail out.mine does run through the ammeter before the battery.If it shows discharge while running,you need to reverse the wire on it.(Probably still wired for your 6v Pos ground still????)
ALL lights wiil have to be changed to 12 v.A 12 volt battery,grounded negative.It will not hurt the starter.
DO NOT forget a ballast resistor for the coil.(NAPA part # IC 34)The coil will have to have it's wires reversed,as well.+ will hook to the ballast,the other side of the balast goes to the ignition switch.The negative side of the coil NOW hooks to the points lead out of the distributor.
Did not realize that you were still 6v system.Any more questions,just ask.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
