Posted by equeen on November 06, 2011 at 05:21:11 from (209.102.248.236):
Yep, I'm an elementary electrical(Pre-K) sort of guy; but here are the questions:
1. IH "Out to run", "In to stop" ignition switch has two wiring terminals. I see no markings identifying either terminal in any way. Thus, is it proper to wire from the ammeter to either ignition switch terminal, then all other wires to the other terminal?
2. I've seen a wiring diagram of a fuse in the wire between "BAT" on alternator to the ammeter. Is this necessary/helpful? If so, what type of fuse/holder?
3. Alternator #1 spade switch wire to ignition. Wiring options appear to include somewhere along the length of the wire: A filament style marker lamp bulb, or A 15 ohm resistor, or A 3 amp 50 volt PIV diode
Of course I could be confused with the above, but my question remains...... What is the purpose of something in this stretch of wire?
4. And, while I'm at it... how do I properly wire the original Delco Remey light switch (photo above)on the Farmall?
Term 1... Term 2... Term 3... (Is the #3 post on the L shaped piece of metal with 2 screws in it including the screw for #1 post?)
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
