Posted by Mr Farmall on November 06, 2011 at 12:35:43 from (69.141.81.182):
In Reply to: Super A Questions posted by Badger08 on October 31, 2011 at 18:20:23:
You may not have a cooling problem but a lean problem. Any vacuum leaks will cause the engine to run hotter than it should. A very common source of vac leaks are stripped main jet plug threads in the carb casting. Alot of the reman carbs use a steel plug that strips out the threads, it should be a brass one.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
