Posted by H2OK9 on November 11, 2011 at 14:46:48 from (76.2.180.31):
In Reply to: C123 valve question posted by hatrick on November 11, 2011 at 14:19:37:
The washers are valve spring shims. They are used for regaining the proper tension of worn or weak valve springs. There is at least two common types of rotators for exhaust valves. one style has a two piece cap with small bearings between the upper and lower halves of the retainer caps and the other popular style has a small cap fitting on the very tip of the valve where the rocker arm makes contact.
Today's Featured Article - Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
