Re: super h belly pump
Posted by Bob M on November 11, 2011 at 15:50:50 from (69.207.87.100):
In Reply to: super h belly pump posted by ajdeereman on November 11, 2011 at 14:38:29:
Removal is fairly straightforward:
- Remove the operating lever, and unscrew the filler pipe and (3) hydraulic outlets
- Remove the dust cover under the belly casting, then remove the pump drive shaft. (Pull the large cotter pin from either end of the shaft then slide the coupling sleeve back to disengage the shaft)
- Support the pump with a suitable saddle jack then remove the (4) 3/8" cap screws from the pump mounting flange. Now lower the pump from the belly. BE CAREFUL! The pump is top-heavy and will "flop and drop" if lowered uncontrolled!!
Alternative to the above step: Get a couple 2' lengths of 3/8" threaded rod and two nuts. Remove two of the cap screws from diagonally opposite corners of the pump flange and replace with the threaded rods and nuts. Run the nuts just snug to the pump flange. Now remove the two remaining cap screws, then lower the pump by gradually turning down the nuts on the threaded rods.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
