Posted by mkirsch on November 14, 2011 at 06:07:04 from (64.80.110.74):
In Reply to: Convert A to Super A posted by equeen on November 13, 2011 at 11:01:32:
The A has an aftermarket/homemade hydraulic pump on it?
Is it on the engine, run by a V-belt?
If so, you can power the Super A's hydraulic block with the aftermarket pump.
The A's front end and the Super A's rear end will bolt right together at the bell housing. That will give you the hydraulic block (aka touch control).
All that's left at that point is to connect the hydraulic pump to the touch control.
There is a hydraulic manifold and lines that run from the pump on the Super A's engine to the touch control. You will need to take that manifold, cut the lines short, and have threaded hydraulic fittings welded or brazed on. Connect the pump to the manifold with hoses.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
