I am talking about the port in rear frame where you took the pump off. When you put the aux valve on demand you are blocking flow so any air you hear leaking is from a problem area. Another thing with those pumps is the short suction tube between pump and filter housing. If you want to do things correctly, you remove the filter and the retainer filter fits into inside so you can install the tube after you have the pump bolted back on tractor but before you tighten it down. That little lip seal the tube goes through is usually in need of replacing and can be tricky to get in without damaging it. I had my own little driver made for that job. For me it just goes with a pump replacement or removal job.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
