Re: IH 300U Going Away.
Posted by Bob M on August 29, 2000 at 09:29:46 from (192.232.120.194):
In Reply to: IH 300U Going Away. posted by ntgreco on August 29, 2000 at 09:14:26:
Problem could be either fuel or ignition. Suggest you try this: Run the tractor until it begins to falter then slowly pull out the choke. If it runs better with the choke partially closed the problem's fuel starvation. Disconnect the fuel line from the carb - should flow a full stream of gas out of the line. If it does not, check for a plugged gas tank cap vent, clogged sediment bowl or "junk" in the bottom of the tank covering the outlet to the sediment bowl. Also check for a plugged or collapsed screen behind the fuel inlet nut in the carb. If the choke doesn't help and instead makes it run worse, look for poorly adjusted breaker points (gap set too small), bad condenser, a failing coil, etc. If any of these parts are suspect, simply replace them all. They're relatively cheap. Good luck!
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
