Posted by Owen Aaland on November 15, 2011 at 14:17:54 from (216.47.34.80):
In Reply to: D436/dt436 posted by tempola on November 15, 2011 at 10:26:01:
There are several different heads used on the 400 series engines. They vary both in air passages and cooling passages and deflectors.
Camshafts are the same between turboed and naturally aspirated but there are different cams used as engine development progressed. Lobe size and grind contours changed over time. Lifter design also changed as well as lifter bore. Truck engines switched to using roller lifters.
There are probably more differences between early and late engines than there are between T and NA engines.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
