Posted by Brownie 450 on November 17, 2011 at 15:42:13 from (66.43.241.198):
In Reply to: a not starting posted by Todd Heck on November 17, 2011 at 14:13:14:
Can also be battery cables where they connect to the battery posts. I am assuming you have a "push rod" to the starter switch, which is mounted on the starter frame. If the ground cleaning & checking the battery posts doesn't help, take the starter switch & battery lead loose & try putting the cable end directly to the starter post which was under the switch. If the engine turns over now, you probably have a bad switch. Check that the starter hot post is not loose. If loose, take the starter apart & tighten the nut from the inside.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
