Re: 504 Won't go
Posted by Janicholson on November 20, 2011 at 15:46:42 from (96.24.99.126):
In Reply to: 504 Won't go posted by angus50456 on November 20, 2011 at 10:36:48:
There are several possible answers: Assumption: The tractor does not bog the engine down when letting out the clutch, it just fails to move, and the engine runs allong just fine.
The Master clutch colud be without enough friction material to operate. (should have been a symptom for a while unless someone borrowed it and wasted the clutch)
The Torsion cushion springs in the clutch disk center can fail (usually with noise and wierd action) but it will not move at that point, or it will not disengage, (keeps moving, not your issue)
The splines on the TA input shaft on the disk can be toast letting the disk rotate W/O the shaft.
The TA could be broken internally and no power going through it.
The TA clutch, and the spargue clutch could be bad.
Did the TA work at all? Jim
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
