Farmall F 20 oil pressure
Posted by Elden Russell on November 21, 2011 at 06:31:11 from (209.169.201.218):
I can't get oil pressure on my F 20. I have taken the oil pump out - every thing seems to be working. I blew out the lines with air and every thing is clear. Apparently the valves are not lubricated from the oil pump as there is oil caps on the valve cover to oil manually. I took the port cover off and turned the engine with the crank and the oil trough and scoop seem to be lubricating the piston bearings on the crankshaft. The only other part that should need oil is the govenor which gets oiled when adding oil. Can I run it this way?
I am new at this. Any hints?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
