If you plug the pickup screen with sludge you of course are in trouble. My point is that on a M farmall tractor you have a bypass oil filter. It receives oil from the same passage that is feeding the main bearings. No oil going through the oil filter goes to the bearings as it is dumped back into the oil pan and then is pumped again through system with the rest of the oil. So, if the filter is plugged you still have oil in gallery feeding the bearings. If the sludge is sufficient to plug the oil gallerys that is a different situation. If the sludge is gritty crud, you are feeding it to all the bearings regardless if filter is plugged or not. A full flow filter receives the oil from the oil pump and from there it goes into oil gallery so if the filter is doing it's job on those systems you will get the crud out. When filter plugs, the back pressure will open the bypass in the filter or filter base and still oil will flow to oil gallerys but it will be unfiltered.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
