Re: Need help with first start-up in 2 years!
Posted by Tom Fleming on November 25, 2011 at 10:17:27 from (206.193.250.146):
In Reply to: Need help with first start-up in 2 years! posted by BigTone on November 25, 2011 at 06:46:30:
If it were me, I would take the drain plug out of the bottow of the carb bowl and drain out whatever is in the tank and the carb. Then I would pour 1 quart of fresh gas through it. Make sure you have good fuel flow. replace drain plug and put about a gallon of fresh in the tank.
Next, check the plugs and clean/gap if necessary. Squirt some oil in each cylinder, don't over do it, but get enough in to cover the top of the piston, and run down the sides. crank enginer over a couple of times with the plugs out.
check fluid levels and condition.
If all is good, put a battery in her and fire her up.
after 2 years, if it takes more than that to start her, she wasn't running well when put away.
IMHO.
This post was edited by Tom Fleming at 10:51:16 11/25/11.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
